Posted by Rob Hays on June 05, 2003 at 08:49:53:
Thanks to all of you who responded to my pump/pressure tank problem. I drained the tank, checked the pressure, checked for h2o out the air valve( there was none), pulled off the gauge & switch w/fittings. The pressure in the tank after I emptied it was off the scale, so bled air down to 32 lbs. I cleaned up all fittings/gauge/switch & reassembled. Then I reset pressure in tank & it's working just as it should. THANK YOU THANK YOU.......Rob
Replies to this post
There are none.
