Re: basment level bathroom
Posted by Deb on June 04, 2003 at 23:43:43:
In response to Re: basment level bathroom
: a quick question on a toilet drain.i am adding an addition to my house with a bathroom. the drain for this bathroom will be piped to the existing septic pipe on a seperate run. the bathroom is below grade ,so we installed a zoller ejector pump and basin into the floor that will be poured soon.my question is the drain leading into the basin under the cement floor to the toilet,(do we need a trap) in this drain pipe?the pluming supply house said we do not need it just an elbow, and the toilet acts as the trap. You do not need a trap. You do, however need a vent. Make sure that all the fixtures, including the ejector are vented corectly. Deb The Pipewench
Replies to this post
There are none. |
