Re: Well Pump on/off, on/off, on/off
Posted by Deb on June 04, 2003 at 23:40:16:
In response to Re: Well Pump on/off, on/off, on/off
: Hube, The cut-in is appx 38 & the cut-out reads appx 60, but when we turn the h2o on the gauge drops from 60 to 38 in a matter of appx 5 seconds, then the pump engages for appx 5 seconds & brings it up to 60. I will try what you suggested & let you know. Thanks to you, Gary, and hj. Take a pressure reading of the air in the pressure tank. This needs to be done with the water drained from the tank. It should be 2#s less than the cut on pressure. Deb The Pipewench
Replies to this post
There are none. |
