| Posted by LonnythePlumber on June 04, 2003 at 23:04:47: | |
| In response to Re: How can I move my bathroom sink over 6 inches? | |
: As long as the piping will still be in the cabinet it is usually a simple job, but without seeing it we cannot tell you exactly how to do it. : : I have a small bathroom in which I want to change out the vanity cabinet and sink. I would like to go from a 25" to a 31". Problem is, if the sink stays where it currently is, the door will hit the 31" sink. I want to be able to install the sink about 6-8" to the left of where it currently is. Is there some kind of extension or pipeing that can be added to the drain pipe to accomodate this without redoing the entire plumbing system? Any creative advice appreciated! You can use a tubular size slip 45. I have not seen the slip 22 1/2 hj refers to and codes do not allow an additonal 90 (1/4 bend) nor should you install one. LonnythePlumber |
| There are none. |
