| Posted by hj on June 04, 2003 at 19:23:28: | |
| In response to Re: Rear Outlet Grading | |
It will work as long as you have a good seal at the toilet. The words "rear discharge toilet" and "cheap" cannot be put in the same sentence. : I am wanting to put a toilet on a slab. I read a previous message on your board that I understood to say that a rear outlet toilet should connect to a vertical pipe so flushing pressure won't cause a leak through the seal. Other messages on your bord indicated otherwise. Can I connect a rear outlet toilet to a minimally graded discharge 4 feet in length before the drain takes a vertical drop? If so, Can you recommend an affordable (cheap) rear discharge toilet that works well.
| There are none. |
