| Posted by Ian on June 04, 2003 at 16:49:53: | |
I am wanting to put a toilet on a slab. I read a previous message on your board that I understood to say that a rear outlet toilet should connect to a vertical pipe so flushing pressure won't cause a leak through the seal. Other messages on your bord indicated otherwise. Can I connect a rear outlet toilet to a minimally graded discharge 4 feet in length before the drain takes a vertical drop? If so, Can you recommend an affordable (cheap) rear discharge toilet that works well. |
