| Posted by hj on June 03, 2003 at 23:55:05: | |
| In response to Re: Shower Arm Flange | |
Either one, or neither. It depends on whether you think you will splash the water that high. : The shower stall is a surround 57" high. The shower arm is about 3" above the top of the surround. I just wanted advice if I should try to caulk it or seal it with plumber's putty.
| There are none. |
