submersible pump well piping
Posted by Ed on June 03, 2003 at 09:49:01:
Is there a method for checking/cleaning out the plastic 1" pipe that runs from the pitless adaptor in the well casing to the inside of a building. The pump has been replaced but pressure and volume seems to be below what it should be. The well pump installer claims the line into the building is somewhat clogged and should be replaced but this would require a lot of digging and breaking up of asphalt. Can a plastic pipe like this be cleaned out from the building to the casing without disconnecting at the pitless adaptor?
Replies to this post
