| Posted by hj on June 02, 2003 at 23:47:47: | |
| In response to Re: Cast iron sewer pipe | |
Fernco couplings are not approved inside the building in many areas. But the more pressing problem is that you seem to plan to just cut an opening into the main pipe and connect your sink and washing machine drains to it. All this with no apparent provision for venting the new drains. : I have an older home with the cast iron sewer pipe in the basement. I want to install a laundry room and need to connect a drain for the washer.
| There are none. |
