| Posted by PW on June 02, 2003 at 11:34:43: | |
| In response to Re: toilet drains to bottom of the bowl | |
Sounds like you may have a vent problem. When the level of the holding tank gets full, the pump kicks in and pushes the fluid to the drain field. Would suspect that when the tank is draining it is sucking out your toilet, should not be! Get your contractor back for a look see.
: In addition the washer drain gurgles randomly. : Any thoughts?
| There are none. |
