leaking seal, mansfield toilet
Posted by Gene Kimble on June 01, 2003 at 17:29:24:
I have two Mansfield toilets in my house both of which leak around the drain seal. The result is periodic refilling and much lime buildup inside the bowl.
I have replaced the gaskets and the drop down mechansism that makes the seal. I am unable to stop the leak.
In my opinion this is a marginal seal method.
I am looking for a conversion kit that will convert to the old fashioned reliable "flapper" seal.
I would appreciate it if you would respond with a conversion kit that is available.
Best regards
G.E. Kimble
Replies to this post
