| Posted by Just Ol' Bob on May 31, 2003 at 13:33:26: | |
| In response to Re: Can't remove sink drain. | |
: : : Please excuse my lack of correct terminolgy for the plumbing parts. I can't get the part of the drain that goes through the sink loose from the pipe on the bottom. It just keeps turning. I can pull it up about 1/2" but no futher. I've removed the J joint. I've looked for something to loosen but don't see anything. There's a section in the pipe on the bottom where the drain plug was connected but I don't see a screw or anything to remove this. I think it's cemented in and have been unable to loose this part either. Suggestions???? :: I imagine you probably have the problem solved by now, but just in case.
| There are none. |
