| Posted by Chris on May 29, 2003 at 13:26:03: | |
| In response to Re: Water Softener Drain | |
If it contains that much salt, then I assume it wouldn't be good to send it to the septic tank and leaching bed either? : Chris: : The water going to the drain from a water softener system is the residual from flushing the resin beads after regeneration with brine. It contains a lot of salt and will kill your grass. I doubt that you really want to drain it to your yard. :
