Re: Commode not flushing everything down
Posted by John S on May 28, 2003 at 23:49:43:
In response to Re: Commode not flushing everything down
I don't really have enough information to evaluate your problem. Is it a Fluidmaster flapper? (I know that theirs has a "dial"). If so, they have a 1-800 number and are quite helpful. (look on a Fluidmaster box for the number) You might try calling them.
: I replaced the flapper after I figured out we had a leak. It has a dial on it that will adjust the flush. (I had this problem before the new flapper) It takes FOREVER for the tank to fill after flushing. Any idea on how to correct that?
: Also, I have to hold the button down until the toilet bowl has emptied in order for it to flush everything down. What adjustment do I need to make?
: Thanks!
: Cathy
Replies to this post
There are none.
