Re: Water Softener Drain
Posted by js on May 28, 2003 at 23:44:55:
In response to Re: Water Softener Drain
Chris:
The water going to the drain from a water softener system is the residual from flushing the resin beads after regeneration with brine. It contains a lot of salt and will kill your grass. I doubt that you really want to drain it to your yard.
: I am planning to install a water softener in the crawl space of my house, but I'm not sure of the best way to run the drain line. Would it be better to run the drain line directly to the exterior of the house, such as to a french drain or can the drain line be installed in the existing drain lines in the house? If the drain can be installed in the drain lines, how would the standpipe be installed since this area is lower than the rest of the house? Thanks in advance.
Replies to this post
