Re: Is this fitting permissable?
Posted by Ed on May 28, 2003 at 12:14:25:
In response to Re: Is this fitting permissable?
: Where are your vents??????: If plumbed correctly, there is no reason to have the WC downstream from a tub, shower or lav. : Deb : The Pipewench I have two alternatives I was considering. #1: Using Air Admittance Valves on all three fixtures eliminating conventional venting. #2: There is a vent above the area where the bath will be located. Unfortunately (?) it is only 1 1/2 in diameter. It presently vents the equivalent of 7 fixture units including a water closet in that count.
I thought about shooting a new two inch vent pipe close to it to the attic (one story home and capthat with an Air admittance valve avoiding another cut in the roof. The stack that goes into the roof is 1 1/2 to 3 inches. It would be easier to do it as I propose. Would either of these methods work? Being Plumbed correctly.
Replies to this post
There are none. |
