| Posted by Ed on May 27, 2003 at 14:30:48: | |
| In response to Re: Basement Plumbing - THANKS TERRY! | |
Thanks very kindly, Terry for your expert advice. It's most appreciated. = ED : : We want to install a full bath in the basement as well as a kitchenette. (4 fixtures) : : Can we branch off a 3" basement drain pipe that already : Yes. : : Regarding venting: Could we use air admittance valves : If they are code in your area, then yes. : : There is a vent pipe connected downstream from the main floor toilet it serves (as well as the other main floor fixtures listed above). Problem (?) it is only : : This 1 1/2 vent serves a horizontal drain pipe in basement joists below floor again serving all those fixtures noted above. : : If we went with conventional venting, would this 1 1/2 vent (one story home) to the roof be adequate to add the 4 new fixtures in the basement? : Most codes would require at least a 2" pipe when the toilet is served. : : If we had to add another vent, could we tie into the attic stack at the three inch point? : Yes : Most of it is in the attic is 3 inches running through the roof...1 1/2 vent going to 3 inches.
| There are none. |
