| Posted by Deb on May 26, 2003 at 10:05:58: | |
| In response to Re: Problem with hot water supply | |
: : There is no "vacuum in the system". The plumber was just giving you a fancy explanation for a simple adjustment. WIthout access to the unit we cannot tell if it is a circualtion or control problem. Most other plumbers should be able to check it and find the problem, if they are familiar with indirect water heaters. : ok, do you live near Massachusetts? :-) Les, |
| There are none. |
