| Posted by hj on May 25, 2003 at 21:54:28: | |
| In response to Re: Problem with hot water supply | |
About as far away as it is possible to be. AZ. : : There is no "vacuum in the system". The plumber was just giving you a fancy explanation for a simple adjustment. WIthout access to the unit we cannot tell if it is a circualtion or control problem. Most other plumbers should be able to check it and find the problem, if they are familiar with indirect water heaters. : ok, do you live near Massachusetts? :-)
| There are none. |
