| Posted by Terry Love on May 25, 2003 at 02:19:38: | |
| In response to Re: Basement Plumbing | |
![]() : We want to install a full bath in the basement as well as a kitchenette. (4 fixtures) : Can we branch off a 3" basement drain pipe that already Yes. : Regarding venting: Could we use air admittance valves If they are code in your area, then yes. : There is a vent pipe connected downstream from the main floor toilet it serves (as well as the other main floor fixtures listed above). Problem (?) it is only : This 1 1/2 vent serves a horizontal drain pipe in basement joists below floor again serving all those fixtures noted above. : If we went with conventional venting, would this 1 1/2 vent (one story home) to the roof be adequate to add the 4 new fixtures in the basement? Most codes would require at least a 2" pipe when the toilet is served. : If we had to add another vent, could we tie into the attic stack at the three inch point? Yes Most of it is in the attic is 3 inches running through the roof...1 1/2 vent going to 3 inches. |
