Re: Outdoor Gas Lamp Installation
Posted by Hube on May 24, 2003 at 18:29:58:
In response to Re: Outdoor Gas Lamp Installation
: I want to install a two mantle gas lamp outside. It uses 1/4" tubing inside the post. I need to run a gas line underground for about 16 feet and then through the foundation into the basement. Can I use copper (perhaps 1/2") tubing underground do I have to use underground rated black pipe & wrapped fittings? Ken: I believe it has to black and jacketed (wrapped), but i would strongly suggest you CHECK the local gas CODES before doing any adding on to your gas piping.
Replies to this post
There are none. |
