| Posted by hj on May 23, 2003 at 22:47:24: | |
| In response to Re: Delta Shower Valve | |
IT may require that the core be taken out and reversed or modified. Again, this will be addressed in the instruction pamphlet. : Thanks. Is it something I need to shut the main valve downstairs off, or is just keeping the shower valve off sufficient? Thanks in advance! : : Take the big round plate off and replace the push button diverter. : : : I have an older Delta Shower Valve that leaks water through the push-button when either the shower or tub is running. Is this an easy fix? : : : Thanks!
| There are none. |
