: I had a new well pump put in and now the toilet doesn't fill. I don't want to spend a lot of $ to fix this. Pls help. Fran, nobody ever wants to spend a lot of $ to get anything repaired :-) You probably have debris 1n the ballcock assembly, the stop, or the riser to the toilet. The ballcock is my first choice for debris. You can shut the water to the toilet off, remove the top to the ballcock assembly, turn the water on slowly while holding your hand over the top of the assembly to flush (and see if this is the problem). If it is, clean and reassemble the ballcock assembly. If not, post back. Deb The Pipewench
