| Posted by hj on May 22, 2003 at 13:44:48: | |
| In response to Re: Where's the problem? | |
If the pressure is low with no water being used then it is not a problem with the piping. Does your system have a pressure regulator like the neighbors? If so, then it is set too low. : My problem is: : I have between 35&40 psi. water pressure to my house from the meter. The meter has the same pressure from the service line across the street. : My neighbors on either side have 118psi to their houses and have their pressures regulated back to 60-80 psi. : There are two mains on the opposite side of the street from my house. A 16" low pressure line and a 12 high pressure line. : Yesterday, the water dept. determined that I was connected to the 16" low pressure line so they tapped my service into the 12" high pressure. : The pressure at my house is still 40psi. However, they did increase the gpm flow from 13gpm to 20gpm at the service side of the meter. : My question is: Why is my water pressure still so low and other houses around me have hose bursting pressure? Could there be a kink in the service line below the street before the line reaches my water meter? : Thanks,
| There are none. |
