Hi everyone. This is a great board! Thanks to all who respond! Here's my challenge. We want to install a basement (full) bath and a kitchenette with sink. #1. May I use Air admittance Valves for each of these fixtures instead of running separate vent line(s)? (AAVs are code compliant in Ohio) #2. Re-drain lines. Which of the following would work best: Running separate branch drains - 1 (3") for the closet and another (2") for the tub, and lavatory. This method would place the water closet downstream from the other fixtures. OR Otherwise all fixtures would need to be rearranged on the floor plan, to keep the watercloset downstream from the others. The third option (sorry I have not done my homework - probably NOT an option -thought I'd ask anyway) Keep the watercloset according to plan but use a wall-mounted fixture and use four closets bends and about 22' 3"inch pipe keeping drain pipe sloped above the floor running the perimeter behind a wet wall until the tie-in point in the floor drain. This would keep the watercloset downstream from the other fixtures. This sounds so far-fectched, it probably is not permissable. Doesn't hurt to ask does it? Current stats: Bath and Kitchenette would be tied into 3" basement floor drain. This existing drain receives wastes from main floor Kitchen sink, dishwasher, washing machine, laundry tub as well as a lavatory, shower and water closet. This (existing) 3" drain system is vented above the watercloset 3" to the roof and the washing machine also has a 2" vent to the roof. Would the 3" basement drain handle the new four fixtures described above along with the present fixtures? Or would it be better to run a new (3") branch drain to the main cleanout (4" pipe)? Thanks again. Much appreciated!
