| Posted by Hube on May 21, 2003 at 12:15:54: | |
| In response to Re: leaking kitchen faucet - under the counter | |
: Our cold water valve is leaking under the sink. It is only leaking when we turn the water on. we have replace the flex pipe leading into the faucet, but it is still leaking. : thanks. You say the valve is leaking. Is it only leaking at the valve stem, or at the in or out portion? If leaking at the stem, either re-pack stem or replace valve. If leaking at either end, try wrapping teflon tape around threads, and re-tighten. If your going to replace valve, first shut off the Main supply line.. Hube
| There are none. |
