| Posted by hj on May 20, 2003 at 09:00:15: | |
| In response to Re: lightweight concrete platform for water heater? | |
If the heater is upstairs it should have a drain pan, with a proper discharge pipe, under it. This would eliminate the need for a concrete, or any other non-wood, support. The leak should have been discovered and fixed long before it could have damaged the heater support. : Hi,...A plumber I talked to about installing a new gas water heater said that he uses a lightweight concrete platform underneath, instead of a wood platform which we now have. Our old platform is rotting due to a leak in one of the copper pipes. Our heater will be 50 gal.
| There are none. |
