| Posted by PW on May 19, 2003 at 16:32:26: | |
| In response to Re: Bath exhaust fan - QUIET options | |
You can go either in-line or roof mounted. Yes they are much quieter. Check out Nutone I have used theirs but I'm sure there are others. It is even possible to have one fan serve all your sources, not sure I like that approach as you are sucking air from all sources at the same time. : I've seen the Panasonic fans listed here as very quiet.
: I'm also looking for the same for over our regular range (30"?). : Thanks
| There are none. |
