| Posted by Deb on May 19, 2003 at 10:45:28: | |
| In response to Re: Air in Pipes when turning water on | |
: : : I travel frequently and have been turning off my water when I leave. However, when I return home and turn the water back on and then turn on a faucet in the house, I get very loud banging - I guess from air in the pipes. I'm afraid I'll damage the pipes. Should I not turn the water off when I go away for a while? Is this loud banging normal? It goes away after I open all the faucets. : : : thank you very much LINDA;The loud banging is not normal,but its a good idea to turn water off when leaving for a few days. We do the same here.You don't say whether your on a city or a country system (well and press. tank) Also do you have a water softener? Post the additional info and we'll try and advise what is causing the noise... Hube : thanks...Hube... Do you turn the power to your water heater off? Deb
