| Posted by Rudy on May 19, 2003 at 04:04:24: | |
| In response to Single handle Pricepfister shower hot water problem. | |
: While drawing hot water for the tub, handle turned to Hot, the hot water discharged slow and gurgly. After I turned the handle, Warm to Cold, the water flowed normaly. Not sure if cartridge is the culprit here? What do you suggest. The Warm to Cold positions flow normally. |
| There are none. |
