Re: Toto Toilet - Drake CST744S leaks where bolts attach tank to toilet
Posted by Terry Love on May 19, 2003 at 00:44:42:
In response to Re: Toto Toilet - Drake CST744S leaks where bolts attach tank to toilet
Elaine,
If the "tank to bowl" bolts are leaking, they may need tightening.
Things to check if that doesn't work.
Remove the bolts, and check the china, sometimes I sand it with emory cloth to knock down rough edges.
The rubber washer should be smooth and clean,
(no plumbers putty here!)
Terry Love
: Two small bolts beneath the Toto Drake toilet are leaking. I believe they connect the tank to the toilet.
: I wonder if I should try tightening, etc. or would be better off ordering new parts, like a seal or something.
: I'm healing from hip surgery and can't afford to disable the toilet by doing something stupid.
: Should I call a plumber or is this something simple to fix?
: Thanks, Elaine
Replies to this post
There are none.
