IF the ring part is magnetic at least she will know why her finger turns rusty red, instead of green. : : Hube, : : If the magnetic strip works, she best not tell the the financee. :-) idon't think diamonds are magnetic, BUT the RING part could be. So if the magnet works, you can tell your beau. Hube : : : : : : : i dropped my engagement ring down the sink in my bathroom tonite ... im living in an older apartment and the connection on the pipes that u would normally unscrew and open is rusted over n i couldnt budge it ... : : : : im wondering any hints apart from sawing open the pipe to see if my ring is in there or is it a waste of time would it be gone now ... i havent run any water since it went gurgling down there and i would really like it back without having to tell my fiancee what happened .... : : : Try a 12" piece of wire (thinner than a coat hanger) bent into a small V at one end and fish for it. Also,a magnet strip MAY work. Put a big loop on the top end of wire, so you don't lose it down the drain when fishing. If no success, then cutting the trap is next. A diy fix for about $15. max. Let us know how you make out. Hube
