| Posted by Deb on May 16, 2003 at 21:29:13: | |
| In response to Re: ring down drain | |
: i dropped my engagement ring down the sink in my bathroom tonite ... im living in an older apartment and the connection on the pipes that u would normally unscrew and open is rusted over n i couldnt budge it ... : im wondering any hints apart from sawing open the pipe to see if my ring is in there or is it a waste of time would it be gone now ... i havent run any water since it went gurgling down there and i would really like it back without having to tell my fiancee what happened .... If you have not run the water since you dropped the ring, there is a good chance that it is still in the p-trap. Since the drainage pipes are in bad shape and will need to be replaced, why not call a plumber and let him or her deal with this. If the ring is saved, it will be well worth it.
| There are none. |
