| Posted by Bob Bailey on May 16, 2003 at 15:14:58: | |
I am replacing some rotted flooring under the closet flange which is attached to PVC drain pipe. I have no idea how that flange is attached to the drain stack or how to get it off. Does it screw in or do I need to cut the PVC to remove it. I have all of the rotted foor removed around the flange. Thanks |
