| Posted by Hube on May 16, 2003 at 13:14:26: | |
| In response to Re: ring down drain | |
: i dropped my engagement ring down the sink in my bathroom tonite ... im living in an older apartment and the connection on the pipes that u would normally unscrew and open is rusted over n i couldnt budge it ... : im wondering any hints apart from sawing open the pipe to see if my ring is in there or is it a waste of time would it be gone now ... i havent run any water since it went gurgling down there and i would really like it back without having to tell my fiancee what happened .... Try a 12" piece of wire (thinner than a coat hanger) bent into a small V at one end and fish for it. Also,a magnet strip MAY work. Put a big loop on the top end of wire, so you don't lose it down the drain when fishing. If no success, then cutting the trap is next. A diy fix for about $15. max. Let us know how you make out. Hube |
