Hot water pipes banging
Posted by Larry Rogers on May 14, 2003 at 21:43:13:
I have a tub that when running hot water the pipes start making a awful racket. You can turn on the hot water and it will be running fine for abou ta minute and then you will see the water flow slow down and then the banging starts. If you turn it off then back on the water flow is good again for a short period. I have also notice that I can't seem to get more than two bathtub full o fwater before I run out of hot water. Could all this be caused by a bad lower element? Any suggestions or hints would be greatly appreciated. Thanks!
Replies to this post
