Old Lavatory wall mounted faucet.
Posted by Roger on May 14, 2003 at 00:34:35:
Hello.. I have an old wall mounted sink in my bath. This sink also has a wall-mounted faucet. I have tried to keep this valve going (even had a broken stem welded once), but it seems as it has finally given in. Does anyone know a source for another wall-mounted faucet that will fit this set up? The sink has the three holes and the faucet valve holes are 5.625" on center, with a third spout hole in the center. Is there any modern faucet that would work??? I've heard about single valves that could possibly be mounted behind with just the handle (and cover plate) coming through the hole, but I don't know a source.. I could possibly adapt the current spout with two new behind the sink wall valves... anyone have a source for anything at all??? Thank you!! Roger
