| Posted by LonnythePlumber on May 13, 2003 at 22:11:24: | |
| In response to Re: Final connections - - after rough-in | |
: Inspectors do not allow bending copper tubing, so you will have to use fittings and solder. : : I am awaiting the roughin inspection and I am courious about the next step. Certainly we use pipe benders but it's usually on 3/8" supplies. I prefer stainless steel flex connectors on the whirlpool tubs but some plumbers are using PEX. I usually connect my shower valves with hard copper but you can use soft copper or PEX.LonnythePlumber |
