| Posted by hj on May 13, 2003 at 19:15:32: | |
| In response to Re: Eljer Tub faucets - how to remove handle? | |
Manufacturers can get creative when it comes to fastening handles to the stems, but if there is a screw holding it one, then that will normally be the only fastener and the handle should pull off. You may need a handle puller to do it, however. : My house was built in 1980 and the faucets in the tub are starting to leak. The controls are 3 knobs (hot, cold, and shower). Each knob has a screw in the middle. Taking the screw out doesn't appear to be enough to remove the knob. From what I have found on this board it appears they could be soldered or I need to use a faucet puller to remove the knob. It doesn't appear to me that there is any solder there and I even heated the knob up for good measure -- no luck. : I haven't been able to find any information out about this specific faucet. Anyone happen to know if the knob puller is a good idea, or any other suggests? : Thanks in advance for any advice : Shannon
| There are none. |
