| Posted by hj on May 12, 2003 at 09:07:00: | |
| In response to Re: mixet shower valve | |
I assume you have the metal fluted handle. You have to essentially pry it off. The same with the temperature lever. The old handle will not fit the new stem so you will need a new plastic handel and temperature lever. : How do I get the knob and lever handle off my old Mixet shower valve? Both are stuck. Is there a hidden pin? Even after I remove the screw from the knob I still can't remove it.
| There are none. |
