| Posted by hj on May 10, 2003 at 16:29:36: | |
| In response to Re: copper pipe vs epoxy restoratiom? | |
You will not be able to see the interior of the pipes, so you will have to go on faith that the pipes were completely cleaned out, and that the epoxy coating completely covered the interior of the pipes. If either did not happen correctly, you could have a recurrance of the problem. : I am needing to replace the pipe in my house. I have been approached by a company that say it can sandblast out my steel pipes and coat the inside of the pipes with epoxy. Any comments for or agaisnt? : Thanks
| There are none. |
