| Posted by Bob on May 08, 2003 at 21:23:00: | |
| In response to Re: Sump pump noisy when it drains | |
Sounds like it may be pumping at too low a water level and sucking a bit of air at the end of the cycle. I am not sure what type of control mechanism you have. Some are easily adjustable. If it is a pressure switch it may need to be replaced. Bob |
| There are none. |
