Re: Refigerator water dispenser
Posted by Joerg on May 06, 2003 at 16:39:20:
In response to Re: Refigerator water dispenser
As HJ hinted it might be the valve. It's a double
valve and when ours quit I was able to get a
generic replacement for about 45 Dollars from a
local appliance store.
If someone presses the button and you listen
to the valve in the back of the fridge and it just
hums but doesn't click then it's very likely shot.
: My water dispenser on my GE side-by-side refigerator has stopped working. The ice maker is working fine so I know the water is getting into the refigerator. I was told there is a valve that might be plugged up - is it something I can replace or do I need to call the appliance repair person?
: Thanks.
Replies to this post
There are none.
