Re: removing old caulking around tub at bottom of tile
Posted by royce robins on May 05, 2003 at 09:24:24:
In response to Re: removing old caulking around tub at bottom of tile
: My surround leaves about 2 feet between surround and ceiling which I will fill with greenboard and then paint. I installed a shower two years ago with the same setup in a bathroom with no exhaust fan and I have had no problems. This is the simplest and cheapest way although you could install cement board and tile up to ceiling also. I think you would need to install greenboard or something to the studs and under the cement board but I may be wrong there. Some surrounds are designed to go all the way to ceiling so it depends on what you buy and how you want to finish it off.
Replies to this post
