| Posted by hj on May 03, 2003 at 16:01:12: | |
| In response to Re: Toliet Paper Roll Got Flushed!! HELP!!!! | |
IF it did not separate then it is caught right at the top of the opening. Use a sponge or wet/dry vacuum to remove the water and then use a flashlight and mirror to look up the bowl. You should be able to see it and if you can see it, you should be able to use a metal coat hanger to dislodge it so it falls back down. : please help me asap!!! what can i do about the accidently flushed down the toilet roll?!?!?!?! i reached in to grab but it's gone! i'm freaking out!!!
| There are none. |
