| Posted by LonnythePlumber on May 03, 2003 at 03:43:15: | |
| In response to Re: installing bathroom dwv... how much cut in subfloor? | |
: The best suggestion would be to hire a plumber. You have a lot of questions and the answers may depend on how your house is built. : : : : My townhouse 3rd floor has a full bath. : : I'm trying to build a new bathroom which will be located on the other side of the wall back-to-back: : : Which means that the sink water pipes can be tapped back-to-back, and shower water pipes can be tapped back to back,,. : : but i'm wondering if the toilet drain-pip can also be tapped in similar fashion as well : : or do i need to run individual toilet drain lines directly to the main-stack? : : As for the vent, i figure i can just run it vertically up to the ceiling and connect it back to the main stack since it's the top-most floor anyway. : : Also, How do actually access the drain pipes underneat the subfloor? I ask this question because I get the feeling that I can't just freely saw through the subfloors from the top as there are supporting nails that hold up all the toilet/tub/sink fixtures in the other side of the wall. If I saw through that subfloor, it would have no support. : : On the other hand, I also don't want to access it from the floor below since doing so will destroy the kitchen-work below. You are talking about water piping and then you jump to the toilet drain piping. You can do the water. Drains are more of a challenge. You cannot tie one toilet drain into another toilet drain without a vent. |
| There are none. |
