| Posted by Gary Swart on May 01, 2003 at 20:53:46: | |
| In response to Re: Loose shower insert | |
If I follow your description correctly, the problem is that the shower faucet is not attached to anything behind the enclosure. There should be some sort of framing behind the enclosure that the plumbing anchors to, probably 2x4s. In other words, the faucet(s) are not anchored to the fiberglass but to solid wood behind. |
| There are none. |
