| Posted by hj on April 28, 2003 at 20:23:31: | |
| In response to Re: Rust from hot water heater? | |
If the rust is coming from the water heater, then replacing it will cure the problem. If it is caused by steel pipes somewhere in the system, then you will still have the problem after replacing the water heater. : Home built in 1975 in Florida. Installed water softener in 2002 and using iron-out crystals. Still have rusty water when using hot water in dishwasher, washing machine, etc.
| There are none. |
