| Posted by hj on April 28, 2003 at 09:35:04: | |
| In response to Re: help | |
You are creating a "make do" installation. A proper deck mount RT faucet, or a conventional in the wall mount tub filler with a deck or extended wall spout would create a "professional" look. Using a wall mount "kitchen sink" faucet will create one that is very "with it" or appear to be a "patch job". When the manufacturer either recommends not drilling the rim, or has provided a thickened area to do it but that point does not work for your installation, then mounting the faucet next to the tub on the surrounding deck area is perfectly adequate in most cases. As far as the drain is concerned, a plastic waste and overflow with a push/pull stopper can be configured for any tub at no extra cost just by cutting the pipes to the proper length. : thanks to both you gentleman. : : : : : this is how I found this message board because I bought a bargain American Standard whirlpool tub at Home Depot except the sales people want to sell me the "ONLY" faucet that will work for the tub for $200+ dollars. The tub doesn't even have pre-drilled holes on the deck and specifies not to drill your own. : : : : : : I always drill my holes for deck mounts.I've not seen instructions that say not to drill your own and don't know why it is said. You can use a wall mount faucet with an extended spout if compatible with your tub.
| There are none. |
