Re: Pop Up Style Tub Drain Removal
Posted by TTA on April 27, 2003 at 17:40:40:
In response to Re: Pop Up Style Tub Drain Removal
Jim, The best place to snake it from is the overflow. You should be able to remove the overflow plate and snake from there. My pop up drain simply unscrews so yours may be different but the overflow should still work the best anyway.If you want to clear out the short run from the tub drain to the P-trap you could try a spraying from a hose directed down the drain but there probably isn't much of a clog there anyway.
Replies to this post
